Discussion topic: Sky glass wont switch on
This message was authored by: Igor1231
I've just received my Sky glass yesterday 25/08/24, and this morning 26/08/24 i went to switch it on and its simply not responding.. red LED light isnt working, switched it on and off, tried different plug socket, changed remote batteries, tried to do recovery process, and still nothing... struggling with this one
This message was authored by: peter-marlow+1966
Re: Sky glass wont switch on
Have you checked  and changed  the fuse in the plug, it might be  that simple?
P c marlow
Avatar for Igor1231
Changed fuse & no difference, also strange thing is the mute button LED is working on the right side of the TV but nothing else is
This message was authored by: IanMcK
Ring sky about this
P c marlow
This message was authored by: roger1949
Sounds like you got one of the duff ones I returned,get them to exchange asap,don't let panther leave until the new one turns on
