03 Jun 2024 05:05 PM
On watching BBC iplayer catch up picture seems very dark
03 Jun 2024 06:26 PM
@Rivermai wrote:On watching BBC iplayer catch up picture seems very dark
What are you watching on iPlayer? It may be that you are watching a UHD HDR stream which can look darker on TVs which don't have a particularly high peak brightness (like Sky Glass). Make sure you are using the Vivid picture setting as it is apparently the best for brightness when watching HDR content.
20 Jun 2024 06:17 PM
I have the 65 inch sky glass and have the same issue the hdr on iPlayer is so dark picture looks good but too dark to watch . Could do with them sorting it there end with a software update if that is possible I've had mine 2 weeks and I'm struggling with that issue also the input lag on the ps5 .
20 Jun 2024 06:20 PM
@Casein wrote:I have the 65 inch sky glass and have the same issue the hdr on iPlayer is so dark picture looks good but too dark to watch . Could do with them sorting it there end with a software update if that is possible I've had mine 2 weeks and I'm struggling with that issue also the input lag on the ps5 .
The Vivid picture mode will push the brightness as high as it will go but ultimately Sky Glass is simply not a very bright TV. It's really a hardware upgrade that's needed, because there's a limit to what software can achieve.
