Discussion topic: Sky glass freezing then resetting
This message was authored by: Steveaxe
Message posted on 26 Sep 2025 08:09 PM
Sky glass tv keeps freezing then resetting. Happens a couple of times a day
Find out more
Message posted on 26 Sep 2025 08:23 PM
Re: Sky glass freezing then resetting
Hi @Steveaxe
Likely poor broadband speed or connection between glass and router. Does your glass get the minimum 25Mbps for HD and 30Mbps for UHD? You can check this in netflix > profile pic > get help > check connectivity.
Also some information on your isp etc might be useful. We are fellow customers and know nothing about you unless you tell us.
MikeAlanR
