Discussion topic: Sky glass channel 922 keeps freezing
This message was authored by: pete1986andrew
Sky sports main event low latency channel 922 keeps freezing on sky glass. I just wonder if there's anyone else is having the same problem? I have to keep turning it over then turning it back and it seems to be all right for a half an hour and then it freezes again. Any suggestions would be grateful. Thanks, Pete
Re: Sky glass channel 922 keeps freezing
@pete1986andrew  Potentially down to bandwidth issues.
What speed are you getting to the TV?
Open the netflix app on Glass and go to get help, run the connection test.
Low latency streams need a bit more constant bandwidth than the regular UHD channels, any fluctuations could cause an issue.
