Discussion topic: Sky glass air
This message was authored by: Josh109
Sky glass air
Was just wondering if you can still connect bluetooth headphones to the glass air i know you can with the gen 2 glass but im looking at buying the glass air for the bedroom and having the feature to use bluetooth headphones would be great
Re: Sky glass air
You can connect Bluetooth headphones to the Air, in the same way as you can with Glass gen2.
