Discussion topic: Sky glass air white stanby light
This message was authored by: ohinever
My sky glass air displayes a bright white standby light. Annoying as this is while trying to sleep, it also suffers from the reported second long switch on and offs.
It's ruining it as a bedroom tv. Any ideas?
This message was authored by: Jporch316
Re: Sky glass air white stanby light
@ohinever
The gen 1 glass had a red standby  light
the gen 2 glass and air both have a white standby light. Not a lot you can do about it unfortunately apart from pop it on a smart plug and set a timer to turn off the electric totally
This message was authored by: ABG73
I've just got a Sky Glass air and suffering same issue. Have tried all the settings but turning to off turns standby light on. Very annoying when I need a dark bedroom to sleep.  Chat GPT says it can't be turned off so either turn off from wall or use a smart plug to set timers or voice activation via Alexa. Surely Sky can update the settings on next update.
This message was authored by: BrynMeurig
Cover it with insulating tape?
