Discussion topic: Sky glass air white stanby light
Message posted on 13 Oct 2025 05:44 PM
My sky glass air displayes a bright white standby light. Annoying as this is while trying to sleep, it also suffers from the reported second long switch on and offs.
It's ruining it as a bedroom tv. Any ideas?
Message posted on 13 Oct 2025 08:16 PM
Re: Sky glass air white stanby light
The gen 1 glass had a red standby light
the gen 2 glass and air both have a white standby light. Not a lot you can do about it unfortunately apart from pop it on a smart plug and set a timer to turn off the electric totally
Message posted on 15 Oct 2025 05:52 PM
I've just got a Sky Glass air and suffering same issue. Have tried all the settings but turning to off turns standby light on. Very annoying when I need a dark bedroom to sleep. Chat GPT says it can't be turned off so either turn off from wall or use a smart plug to set timers or voice activation via Alexa. Surely Sky can update the settings on next update.
Message posted on 15 Oct 2025 06:05 PM
Cover it with insulating tape?
