43
This discussion topic has been answered Discussion topic: Sky TV technical fault
This message was authored by: Reevo87
Re: Sky TV technical fault
Ours has been working fine through the day, but seems to be issues using the remote and the voice, with the outages last night did anyone else have problems with the voice?
Doesn't seem to be picking much up tonight either but the channels are working.
Sky Glass Gen2 65"
Sky Air 43" in bedroom
LG 65" TV with Puck in spare room.
Broadband with Seethelight as on new build estate that does not support Sky.
This message was authored by: Annie_Collett
Technical fault for 2 days now
Yesterday evening and this evening my to keeps dropping out and displays that there is a technical fault. I am continually having to reset by turning off and then on again. Am really fed up with this now. Getting Sky Glass was the worst decision. Can anyone help with how to get a resolution to this problem?
This message was authored by: Chrissy27
All channels technical fault since 21.05
All channels say technical fault try again later has been dong this since 21.05 nothing helping
This message was authored by: TheHarpers
Re: All channels technical fault since 21.05
The same
This message was authored by: Steve_D
I'm continually getting same msg. My tv is stuck on channel 4. Won't change at all.
This message was authored by: Richardgarioch
Technical Fault Try Again Later
I have been getting this message since I changed over to Sky. If you are getting this please let me know as I think it's a common issue but Sky support don't seem to be aware of it which I don't believe for a minute.
Tried everything giving up now time for bed lol
This message was authored by: Lyn37
Mine has a technical fault on all channels. Home Screen is fine but can't watch anything. Have tried all the regular fixes like turning off at plug for a minute and then turning on again. Have also tried turning the router off and then on again after a minute. Nothing is working.
This message was authored by: Rum230
Re: Technical fault for 2 days now
Same here. One issue after another. Bad decision to buy Sky Glass Air!! And trying to contact Sky is just one huge obstacle to trying to get an engineer
Re: Technical Fault Try Again Later
Sky support is no help. And don't get me started on that silly 'chat' thing that appears!!
@Rum230 there's no engineer support for Sky Stream. What did Sky suggest when you contacted them?
Haven't contacted them yet as still looking for a phone number.
This message was authored by: Zennor
Me too. Only Netflix works on my sky puck
This message was authored by: Ashleystrawberr
Hello
i just received my sky glass tv and have the same issue. I need restart the tv in order to switch the channel on live tv. Also my movies in sky store get stuck loading. Everything else works and plays fine
Answered - Go to Answer
