Discussion topic: Sky Q to Sky Glass
Message posted on 24 Jun 2025 04:15 PM
Sky Q to Sky Glass
Can somebody explain the differences between Sky Q and Sky Glass please?
Message posted on 24 Jun 2025 04:27 PM
Re: Sky Q to Sky Glass
Sky Q is a box connected to a satellite dish which you connect to your TV. It has the ability to record onto its built in hard drive, anything you want to watch later.
Sky Glass is a TV and is designed to replace your existing TV. It does not record, instead it streams everything via your broadband connection. You must have a broadband connection speed of at least 25Mbps for it to function at all. Instead of recording you create playlists which allow you to watch on demand via various apps.
Sky Stream is a small box you can attach to your existing TV and will stream everything the same way that Sky Glass does, just without you having to buy the Glass TV.
Message posted on 24 Jun 2025 04:56 PM
@SuziBee Maybe this will help too?
https://www.trustedreviews.com/versus/sky-glass-2-vs-sky-q-4593555
Message posted on 24 Jun 2025 05:16 PM
@SuziBee Also note that the line up of channels differs between the two platforms
