4
This discussion topic has been answered Discussion topic: Sky glass and Bluetooth transmitter.
This message was authored by: Mistapike
Hi. If anyone has any idea/solutions, much appreciated....I would like to be able to connect two sets of wireless headphones (simultaneously) to my Sky Glass TV. By default only one Bluetooth device can be active at any one time. On paper the solution would seem to be a "Blutooth Transmitter" but these all seem to require connecting to the TV via an audio Jack, which glass doesn't have. Therefore I can't find a solution which allows Glass TV sound to move totally wirelessly from the TV, to two sets of wireless headphones. Any ideas please ?
Re: Sky glass and Bluetooth transmitter.
@Mistapike
You would need to use an (e)ARC HDMI audio extractor on HDMI port #2 in order to have a source to work with
@Mistapike
Avatar for Mistapike
Thankyou very much for the advice TimmyBGood that has done the job 🙂
This message was authored by: Tweeties
Can I ask, which one you purchased? I have a similar issue with my Bluetooth sofa
speakers. Only one will connect to my sky glass TV
thanks
Hi. It was this one, though it's now shown as out of stock/unavailable
https://www.amazon.co.uk/dp/B0C65DTX7P?ref=ppx_yo2ov_dt_b_fed_asin_title
also you'll see mixed reviews, depending on your exact audio requirements
cheers
