This discussion topic has been answered Discussion topic: Sky Has Nerfed The Use of Sky Q Remote
Message posted on 20 Aug 2024 05:12 PM
With the latest 30.520 update that has infected both of my Glass TVs this morning, Sky has killed the use of Sky Q remotes. They now don't pair over Bluetooth and are sadly only using IR now - so no voice command using the remote. Deliberate or oversight?
Sky Glass 65” [Gen 2] with Sky Live
Sky Glass 43” [Gen 1] with Sky Live
Sky Glass 65” [Gen 1] in ‘dumb’ mode (thanks to Sky’s device limits)
Sky Stream Puck x4
Sky FTTP
Message posted on 23 Aug 2024 01:25 PM
@82bit My stream puck was updated last night and unfortunately as you say you can no longer pair the Sky Q remote to operate Stream (and Glass as in your case). It will work in IR mode though which is how I use mine with my Stream remote as my primary which is connected via bluetooth.
If my post has solved your issue please mark as an "Answer"
Message posted on 21 Aug 2024 09:29 AM
Re: Sky Has Nerfed The Use of Sky Q Remote
@82bit wrote:With the latest 30.520 update that has infected both of my Glass TVs this morning, Sky has killed the use of Sky Q remotes. They now don't pair over Bluetooth and are sadly only using IR now - so no voice command using the remote. Deliberate or oversight?
Hi .... have you tried a complete power cycle after the update ? Pull the plug for a few minutes
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
Message posted on 21 Aug 2024 10:23 AM
Message posted on 21 Aug 2024 04:21 PM - last edited: 21 Aug 2024 04:22 PM
@Jporch316 Yes indeed, several times. No dice.
Sky Stream Puck x4
Sky FTTP
Message posted on 21 Aug 2024 04:24 PM
@Kenny-J it's a more logical and fully featured remote - actual REW and FF buttons for a start. Just a preference.
Sky Stream Puck x4
Sky FTTP
Message posted on 21 Aug 2024 04:26 PM
@82bit wrote:@Kenny-J it's a more logical and fully featured remote - actual REW and FF buttons for a start. Just a preference.
The Q remotes have much better build quality too. I had one that lasted 3 years without a single fault.
I had Sky Stream for less than a year and three remotes failed in that time.
