24 Sep 2024 10:03 PM
@Paulbuckland557 yeah me got no solution to the problem just stuck on.it apparently
24 Sep 2024 10:19 PM
Thanks mate appreciate the advice - shall I just call the customer support number or is there another way to get in touch?
24 Sep 2024 10:46 PM
Come back from a weekend away to find the sky glass TV won't turn on.
Turned off at the mains, held power button, switched on until red led flashes and sky logo comes on.
Then get a blue screen saying updating software, says connecting directly underneath for about 5 minutes, then goesmto a page asking me to press 7+9 for 2 seconds, then when I press continue it says software error and gives a qr code telling me to do what I've just done. It gives me a reboot option but that just starts the process again.
I've got 2 pucks in the kids bedrooms and they have been completely unaffected luckily.
But our main TV seems to be a casualty in all this.
Am I going to need a new TV?
24 Sep 2024 10:48 PM - last edited: 24 Sep 2024 10:56 PM
@Jodie1306 wrote:I will maybe need to find a cable.. thats the computer cable ? With the clicky ends ?
Yes, love your description of it.
The Kenable basic ones work well and are good value, if you do not already have one.
You can choose the length, to go from your Sky Glass Tv or puck to your broadband router.
https://www.amazon.co.uk/dp/B019ZUD1I8?ref=emc_s_m_5_i_atc
Sky Community Superuser. What is a Superuser? Click here to find out
24 Sep 2024 10:51 PM
I did finally manage to get it resolved after spending over a hour and 40 minutes on hold on my third attempt to get through to customer services
24 Sep 2024 10:54 PM
Thankyou x
Thats whats happening to me. Im going to try the ethernet cable reboot in the morning
24 Sep 2024 11:14 PM
@Jodie1306 wrote:Thats whats happening to me. Im going to try the ethernet cable reboot in the morning
They got various length ones in Argos but you sometimes get yellow coloured ones in the box with your internet router .....
24 Sep 2024 11:16 PM
@Fayebee83 wrote:Come back from a weekend away to find the sky glass TV won't turn on.
Maybe ..... you could try connecting your tv to the router with an Ethernet cable and trying the recovery procedure again
25 Sep 2024 12:35 AM
I have a 55 in skyglass TV, when plugged in,the red standby light is not showing,but the microphone button on the side of the TV lights up for about 10 seconds, what can be done, this TV is less than 2 years ago,isit still under warranty.
25 Sep 2024 12:40 AM
I have only been with sky for 2 mo tgs, never used any more than the o e e.ail address I currently use with them
25 Sep 2024 12:50 AM
My Sky doesn't work either
25 Sep 2024 05:58 AM
@Jporch316 Thank you. SKY STREAM NOW WORKING. I changed my email address a few months ago and was using this as my sign in. Didn't realise the old email which I set up account with was still being accepted as a sign in too. I signed in with this and was able to activate the code. Yayyy
25 Sep 2024 06:48 AM
@PT57 wrote:@Jporch316 Thank you. SKY STREAM NOW WORKING. I changed my email address a few months ago and was using this as my sign in. Didn't realise the old email which I set up account with was still being accepted as a sign in too. I signed in with this and was able to activate the code. Yayyy
Brill ..... glad it all worked for you!!
25 Sep 2024 06:52 AM
@Ronno61 wrote:I have a 55 in skyglass TV, when plugged in,the red standby light is not showing,but the microphone button on the side of the TV lights up for about 10 seconds, what can be done, this TV is less than 2 years ago,isit still under warranty.
You need to carry out the recovery process as advised on post 2 of this thread ....
pull plug from tv
hold standby button in (bottom right of tv)
put plug back in while still holding standby button
keep holding standby button until light on front of tv starts flashing
leave standby button go
follow on screen instructions
