4306
Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by SheilaTequila This message was authored by: SheilaTequila
Re: Sky Glass Power up Issues 19-9-24
I didn't have to do anything with router - just automatically connected.  Each stage was easy - and I'm 74!!  lol.
This message was authored by Billd This message was authored by: Billd
done what was asked still no Tv. When will Sky fix this?
This message was authored by Fothergill1 This message was authored by: Fothergill1
@Killgore77 wrote:
What about connecting to router after you finally get it back on.
@Killgore77 Connecting to the router is one of the steps in the recovery process so make sure you have your router password handy 😀
If my post has solved your issue please mark as an "Answer"
This message was authored by Ryan981 This message was authored by: Ryan981
Re: Can’t connect to Sky stream
Yes same issue been waiting 2 days now for them to sort it
This message was authored by Dan01901 This message was authored by: Dan01901
This is getting ridiculous now! Sky services always down or having problems I pay good money for this and always have problems it's shocking!
@There4u wrote:
What is a puck plug
@There4u  they are referring to the 3 pin plug that you put into the wall socket.
In that case - no idea what's wrong.  Did you follow the new update on answer one.  I only did that - each stage - and now I'm watching the news.  Good luck.
This message was authored by Matt02021 This message was authored by: Matt02021
Pressed it for 2 minutes. Nothing
GD1
Have  you followed the guidance in the post marked as answer?  Have you tried any of the steps?
This message was authored by Johnhorn1976 This message was authored by: Johnhorn1976
What if it's a puck not the main TV... tried everything and still flashing white light and it then goes off.
This message was authored by AngelaAllen This message was authored by: AngelaAllen
Hello tried everything my tv will not even turn on at all
😢😢😢 I only pressed for about 20 seconds then it started flashing - removed my finger then.  Sky came on and start up continued.  🥴
This message was authored by docer64 This message was authored by: docer64
Does anyone have a workaround for being stuck on Link Your Account screen, on Sky Glass? Code input successfully on a web browser but this doesn't appear to link back to the TV. Tried multiple hard resets, factory resets with no joy
This message was authored by Paul+Dray This message was authored by: Paul+Dray
@Patsie wrote:
That doesn't work because I've been stuck on this screen no matter what I do!
When you press buttons 1 & 3 together for a few seconds you have to point the remote at the front of the Puck as at this stage it is only working as a regular 'line of sight' remote and not Bluetooth until you connect it.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck; Build: QS030.528.00P | Sky Broadband Ultrafast
This message was authored by lettice This message was authored by: lettice
Follow the procedure that mentions Sky Stream exactly as described in post 2 of this thread, flagged as the Answer post from Sky.
https://helpforum.sky.com/t5/Sky-Glass-Live/Sky-Glass-Power-up-Issues-19-9-24/m-p/4757859#M147519
Locked
