Discussion topic: Sky Glass Power up Issues 19-9-24
Message posted on 20 Sep 2024 03:45 PM
Re: Sky Puck & Sky Glass Power up issues 19-9-24
After a full reset and re initialisation of all devices I have been fault free for two hours . Ok did take two of us to reset the sky glass TV
Message posted on 20 Sep 2024 03:46 PM
Re: My sky mini tv box light flashing wont stay on cant connect to tv
Dont know what box is called its about 4 inches square by 3 quarters inch thick with sky written on top it connects to tv for tv channels
Message posted on 20 Sep 2024 03:49 PM
Re: Sky Glass Power up Issues 19-9-24
Sadly still only two out of 3 picks and glass Tv not working after trying to follow your instructions so I'm down 1 Puck and my sky Glass 55 " are you still trying to fix this issue? Ring is a waste of time.
Message posted on 20 Sep 2024 03:51 PM
Re: Sky Puck in bedroom
Same here. It's been dodgy since yesterday evening. Think there's an issue. Hopefully gets fixed soon.
Puck not working
I'm not getting a flashing power button unfortunately
Message posted on 20 Sep 2024 03:53 PM
Puck or Glass?
Message posted on 20 Sep 2024 03:54 PM
Re: Sky glass still not working
Well sorry but why paid for something want not working
Message posted on 20 Sep 2024 03:55 PM
It's a Puck. I 2 that aren't working
Message posted on 20 Sep 2024 03:56 PM
@Leo-lion123 wrote:Hi my sky mini tv box light flashing wont stay on will not connect to tv
Seen your later post asking about what you have. You have a Sky Stream puck.
Follow the procedure exactly as describe in post 2 of this thread, flagged as the Answer post from Sky.
If you have a Sky Glass Tv, follow that section.
If you have the small square black Sky puck, follow the one for Sky Stream.
https://helpforum.sky.com/t5/Sky-Glass-Live/Sky-Glass-Power-up-Issues-19-9-24/m-p/4757859#M147519
I have one sky glass and 1 sky pick not working
Message posted on 20 Sep 2024 03:57 PM
Re: Sky Glass Pucks not working
I've tried every thing to get my Glass Pucks working to no avail and been on the phone to Sky for over 30 minutes with no reply so have given up. Any advice would be welcome
Re: Can't get past "incorrect pin" on setting up sky stream
Having the same issue, has anyone managed to figure it out? Thanks
Now it says, I can skip that part and set it up later. but "no" it just takes me round to sky.com/ activate and some obnoxious terms and conditions blurb, Still got the same activation code. I have a 1gb connection courtesy of another provider, Thank God. Service checker says I have a problem with my TV?!!! Really!
Message posted on 20 Sep 2024 04:01 PM
@VeryMiffed The activation page will not work unless you are signed into your MySky account. If you are not you will get an error message. If you are signed in then I would suggest signing out and back in again.
