4306
Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by Jayne.+Singleton This message was authored by: Jayne.+Singleton
Re: Sky Glass Power up Issues 19-9-24
I followed the instructions to hold power button for ages then red light started flashing then followed sky's instructions  and I'm back up and working, no TV since 8pm yesterday thank you Sky community
This message was authored by Georgey98 This message was authored by: Georgey98
Re: Sky glass won’t turn on
Has anyone been lucky enough to be informed of how long this issue might be to get repaired?
This message was authored by Catlover1952 This message was authored by: Catlover1952
Re: Sky Puck & Sky Glass Power up issues 19-9-24
Sorry standby not reset button lol. Still recovering from messing with the damn thing lol
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: What's happening with sky in Greenock no connection since yesty
@Angeladocherty
You've posted in the Sky Q board. Are you referring to the problem affecting a lot of Glass and Stream customers?
This message was authored by Zoejack This message was authored by: Zoejack
Sky glass
My sky glass won't turn on no led light either help
This message was authored by Debzladyowl This message was authored by: Debzladyowl
Will my Sky Glass Tv ever turn back on ????
Will the Sky Glass Tv ever work properly???? We are seriously thinking about getting rid !!!!
This message was authored by Jess242 This message was authored by: Jess242
My sky glass isn't powering on since yesterday and remotes aren't working either? Is there an issue that's currently being fixed with all of them?
This message was authored by Bavoir29 This message was authored by: Bavoir29
Re: SKY GLASS TV WONT TURN ON NO RED LIGHT
Hi, I had the same problem since yesterday. Try this. Switch off at the wall, wait a few mins then switch back on. Press and hold the button button at the side until the red light comes on. When it does, release the button. Then let it go through its sequence. It takes a while and the screen goes blank a few times but be patient. It just worked for me. Good luck.
This message was authored by FL19 This message was authored by: FL19
Follow advice from other users. Press button on side whilst partner switches off plug then switches back on. Let tv do its thing then follow instructions on screen. You will need to go into sky.com/activate and input verification code given on tv.
Thank you it worked for me followed your instructions. No TV since 8pm yesterday
This message was authored by Linda1707 This message was authored by: Linda1707
I can't get my sky glass tv on just fading red light
My sky glass won't come on 2 days now still the same just flashing red light
This message was authored by TARAMATT70 This message was authored by: TARAMATT70
Re: No Sky on TV since yesterday
HOW MUCH LONGER IS SKY TV GOING TO BE OFFLINE
This message was authored by Faya9 This message was authored by: Faya9
Couldn't watch 1st half of the champions league match, went ti work with my sky glass, isn't working
Just finished my last shift of the week, got tea and sut to eatch tv. Just to realize still I can't turn my tv on,
Called customer support and I'm still waiting 1h:l5min on the waiting so far !!!!!!!!
what a disappointment, regretting buying it
This message was authored by Rich114 This message was authored by: Rich114
Anyone help with the sky puck, I've reset it and done the activation code, but won't let me pass the pin stage, changed pin etc but still won't work, anyone got a work around?
This message was authored by Davina3 This message was authored by: Davina3
Thank you, I did try that yesterday! No switch or light turns on. There's no shortage of power which is strange - the remote works..!
Locked
