4306
Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by 82bit This message was authored by: 82bit
Re: Sky Glass Power up Issues 19-9-24
I've 2 Glass and 4 pucks - all bricked. You're telling me I have to factory reset each one and then re-configure and sign in to multiple different apps on EACH device one by one?
Thanks Sky. Just how I wanted to spend my Friday night.
Sky Glass 65” with Sky Live
Sky Glass 43” with Sky Live
Sky Stream Puck + Sky Soundbox
Sky Stream Puck x3
BT FTTP:
↓920Mbps
↑110Mbps
This message was authored by 75jim75 This message was authored by: 75jim75
Followed the reset instructions for my puck. Got stuck on the reset pin page but its all good now after turning off, leaving for a few mins, and back on again.
This message was authored by Kirby+Grip This message was authored by: Kirby+Grip
I have tried everything all to no avail. Phoned on the phone for over an hour. Tried again at 16.09 still holding at 16.54 tried again didn't get  to choose your music for holding on option got the engaged tone, I am absolutely exasperated all day long it's unacceptable. I do no know what else to do. I'm a Pensioner and Disabled I really do not know what to do next. I have been a Sky customer for 7 Years.
This message was authored by temglenn This message was authored by: temglenn
Has anyone else found that the TV is on, but the screen is just completely blank? We managed to reboot this morning and it worked, but since then it's black screen of death and the reboot doesn't work
This message was authored by Maxwell10 This message was authored by: Maxwell10
Thanks all good now everything working 😁
This message was authored by TP63 This message was authored by: TP63
Same hear got tv on set up etc but the code was their but your password and account don't link up .weird it's still a battle ongoing for hours now ..
This message was authored by nadia9 This message was authored by: nadia9
Sky Stream outage
im trying to find out why my sky stream is not working. i cant contact sky. Ive seen the article to reset internet hub because of an outage  but still no joy and the whole of sky seems to be uncontactable. Any suggestions please.
This message was authored by Paul+Dray This message was authored by: Paul+Dray
@TimmyBGood wrote:
@Paul+Dray wrote:
On a serious note, I'm not actually sure how they are going to be able to fix this over the air as the puck is essentially caught in a continuous loop of coming out of standby to show startup logo and then switching to standby for a brief time and repeat.. Sky sending an update command (when they finally fix it) will have to catch it at the right time one presumes
If an operating system isn't booting then by definition it's not possible to push a fix to it because there's nothing to connect with*.  The options are the user manually initiating a recovery procedure, or a hardware swap-out.
*which is why serious hardware has a separate OS embedded in silicon.
This is what I figured. It does make this whole issue even more serious than initially thought. For instance I have some older relatives that would struggle to sort this out themselves. Think a poorly tested software update has created quite a bit of extra  work for Sky. Hope they learn from this.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck; Build: QS030.528.00P | Sky Broadband Ultrafast
This message was authored by Matt02021 This message was authored by: Matt02021
Just tried again. Still not seeing this red light mentioned in the in the re setting notes. Just flashes white, then nothing. Its been over 24hrs still no joy. Can we have some transparency from sky at the very least, so we know what is going on? If I don't get the issue solved by tomorrow morning, I've going to look to cancel and sign up with another streaming service
This message was authored by Shannonv22. This message was authored by: Shannonv22.
Re: Black screen
Mines exactly the same since yesterday ..staying on the black screen I reset but not doing anything 😑
@Billysyme29 wrote:
Came home from work to find my sky glass stuck on a black screen and the red light blinking slowly did a hard reset and it comes up with the software update screen goes to 100% completes the update then goes back to black screen then the sky logo shows up in white then goes back to black and the red light slowly blinks agen any help is appreciated
This message was authored by Pippa29 This message was authored by: Pippa29
Re: No Sky glass all day!
Tried it all! And still nothing
This message was authored by SheilaTequila This message was authored by: SheilaTequila
I'm following what the Sky Employee said on answer one.  It seems to be working - it's updating software.  Thanks for replying.  👍
Mine is updating now - following the No 1 answer from Sky employee.  👍
So it's a software update?!
OK I'll try it one more time, then I'm giving up. And turning it off at the wall maybe better luck tomorrow. Pay all this money for sky ! Honestly
This message was authored by JordanStoughton This message was authored by: JordanStoughton
This whole outage thing needs sorting out we have now been a whole day pretty much without a tv which we pay for and the sky channels too so I hope Sky will be reimbursing customers in some form!!!
Locked
