3831
Discussion topic: Sky Glass Power up Issues 19-9-24
This message was authored by Louisejb This message was authored by: Louisejb
I can’t connect to my sky stream at all
Is anyone else having problems it's been not working for two days now. The remote and puck are lighting up but it won't connect...
This message was authored by dzy82f This message was authored by: dzy82f
Re: Sky Glass Power up Issues 19-9-24
@Brian225 wrote:
Just spent 2 hours on the phone, holding on then talking to an agent. Puck now works and I'm watching the telly again. Its a software problem that stops the tv from recognising WiFi but Sky agent was able to talk me through the recovery process. So if you're without your service ring them up it'll take a few hours to resolve, enjoy your Sunday.....
@Brian225
@lettice
@Daniel0210
This seems to describe my issue. Can you describe how the agent resolved it for you?
Many thanks
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: I can’t connect to my sky stream at all
@Louisejb
I've moved your post into a large thread discussing this issue. Sky are aware and working on it. See post 2, currently showing as the answer.
▪️I AM NOT A SKY EMPLOYEE ▪️
This message was authored by Havill This message was authored by: Havill
Re: My sky stream puck has not worked for 3 days . Reset several times as per instructions still not
I've just looked bk on the customer chat and so far I've got 196 complaints ref to sky glass and the non customer service card
sky get your act together, what would you do if you lost all these customers?????
This message was authored by lettice This message was authored by: lettice
This is the resolution that you have to try.
It has worked for many Sky Stream and Sky Glass TV customers over the last three days with the issue.
Follow the procedure exactly as described in post 2 of this thread, flagged as the Answer post from Sky.
Try holding down the button for as long as possible, it won't harm keeping it pressed longer than mentioned, but release when you see the blue screen instructions on screen.
https://helpforum.sky.com/t5/Sky-Glass-Live/Sky-Glass-Power-up-Issues-19-9-24/m-p/4757859#M147519
If you have any issue with activation during the process or entering the pin do the following;
Activation problems:
Try refreshing your browser cache or try the activate link in another browser or device.
Before clicking on the activate link, log in to your MySky account first.
Also, try this alternative link;
Make sure you have logged into your Mysky account in your browser before trying.
https://www.sky.com/productsettings/streaming-tv/activate
Also, you could try using a mobile phone, not connected to your home broadband.
Pin problems:
When at the pin stage and it fails.
Remove the power from your Puck or Sky Glass TV,  leave off for a few minutes and repower.
It will continue, follow the instructions.
This has worked for many having a pin issue
Sky Community Superuser. What is a Superuser? Click here to find out
Sky Stream (2 pucks), Sky Ultrafast + using Sky SR203 hub. Sky Protect kit tester.
This message was authored by Mark39 This message was authored by: Mark39
Have you followed the recovery process? At what point were you unable to get any further?
This message was authored by gazh425 This message was authored by: gazh425
Any ideas as to when the issue with sky glass will be sorted
This message was authored by Beardsly1 This message was authored by: Beardsly1
Re: Sky stream not working
Red light still flashing on and off , no change at all really is getting ridiculous now ... no tv for 4 days def need some help here
No sky glass no tv for 3 days
Been with out sky glass for3 days this is not funny anymore if I don't recieve a proper service  I will go with virgin or bt on the customer chat I've got 196 unhappy customers
wot would you do if we all left sky  discusting service and NO CUSTOMER SERVICES AT ALL
the amount of time I've tried to phone as well absolutely ridiculous get it together, Sky otherwise you'll be losing a lot of your customers
Just no different from Thursday completely dead other than red flashing light
This is the resolution to try.
Pin problems:
This message was authored by JoJo6664 This message was authored by: JoJo6664
Sky Stream Puk
We have 2 sky Puks and one has stopped working. We have tried all the usual unplugging etc etc but it will not load to the home page??? 5  days now and just get put on hold when calling Sky to which nobody answers! Any help or advice welcome please??
This message was authored by NeilM46 This message was authored by: NeilM46
I can reboot my sky stream puck but when asked to link my account with the pin I goto sky.com/activate and see an error unauthenticated error even if I'm logged into my sky.  No way around it, tried to speak with sky yesterday and after 1h 45 on hold I was told I'd be notified by text when it was fixed.
Has anyone had same issue, been able to resolve?
This message was authored by MahendranMuruga This message was authored by: MahendranMuruga
Any suggestions if we don't have any stream subscriptions, I can't try that alternative link in case if I don't have any product subscriptions.
This message was authored by zalenaharrowell This message was authored by: zalenaharrowell
No sky glass the sky glass does not switch on 2 days now
My sky glass does. Not turn on the screen is blank for 2 days now your help and advice would be most appreciated
