Discussion topic: Sky Glass Power up Issues 19-9-24
Message posted on 21 Sep 2024 09:51 AM
Re: Sky puck stopped working , tried rebooting everything still no joy
@Ctfc Have you tried the steps provided in post 2 (post marked as answer) of this thread which should work for most people, unplugging the puck and resetting the hub won't do anything for this issue.
Message posted on 21 Sep 2024 09:54 AM
Re: Sky Glass Power up Issues 19-9-24
Doesn't work
Message posted on 21 Sep 2024 09:55 AM
Keldrew, we have the same problem here. Only been with sky since March, can't wait for our contract to be over. I thought virgin were bad, but sky are far worse for not giving a reliable service!
Message posted on 21 Sep 2024 09:56 AM
@Ctfc wrote:My elderly parents sky puck has stopped working, tried everything from resetting, rebooting, internet reboot, nothing..
There is a step by step recovery guide on post 2 of this thread that will get your device back working
@Karen2021 wrote:I have tried this numerous times over last 24hrs and still not working. Any help please!
Where is is going wrong ?
Message posted on 21 Sep 2024 09:57 AM
About my sky glass tv
Re: Streaming tv
@Davey6 wrote:
Tv went off 4 pm Thurs when everyone seemed to have problems have tried to reset the pucks as both are still playing up loads of times all starts off ok but when get to the pin number section won't recognise any pins even new pin numbers I've spent hours trying to change pin numbers but won't let me do anything wish I hadn't come over to sky now should have stayed where I was
When you get to the PIN number screen pull the plug on your device for a few minutes then plug it back in and the process should complete
Message posted on 21 Sep 2024 09:58 AM
Think I have finally got it working! Created a mobile hotspot on my phone and it then connected to my router via that and did the update in a minute or so. Will try connecting directly in a bit when I've finished watching what I'm watching on my previous Samsung tv that I luckily still have
@Deborahmck wrote:
My sky TV is off near 2 days! It won't fix by reseting it. It is really cracking me up
There is a step by step recovery guide on post 2 of this thread that will get you back up and running
Message posted on 21 Sep 2024 09:59 AM
Sky Stream reboot
After reboot it will not accept my 4 digit pin? have tried re-setting the pin but when you have to re-enter it comes back saying its not correct????
Tried to change it 3 times now and it just wont work?
Message posted on 21 Sep 2024 10:00 AM
The only public advice from Sky is this recovery method https://www.sky.com/help/articles/sky-glass-stream-wont-turn-on which works in the majority of cases. However you must follow the instructions exactly. Vitally dont release the power button until the led starts flashing red/green rapidly.
if it wont work then your only other option is to call Sky but it is lekely they will walk you through the same process.
Message posted on 21 Sep 2024 10:02 AM
For those who still can't get their Glass TVs reset.
Before you start connect it by Ethernet to your router, then the best way is to get someone to help you.
Unplug the Glass, leave it for 60 seconds.
Get someone to firmly hold the standby button in, and do not let it go whatsoever, now plug the Glass in. Keep the standby button held in do not release it.
Some articles say let the standby button go when the LEDs flash, but out of the 4 Glass TVs I have reset for family members is to keep the button held in until the Sky Logo appears, only once the Sky Logo appears let the standby button go.
As I've said, I've reset 4 Glass TVs including my own on the first attempt and that was by getting someone else to help and not letting that standby button go.
I think what might be happening is while folk are plugging in pressure without realising it is being released during the bootloader process.
Re: Outage in area
@Marie96 wrote:My sky Streaming service is still down and it as been at least theee days and I have been told engineers are trying to fix the problem.
Also can I have a timescale of when the likelihood of this being fixed. Regards Marie
There is no fix that will just happen.
This is the resolution that works, that you have to do.
Follow the procedure exactly as described in post 2 of this thread, flagged as the Answer post from Sky.
https://helpforum.sky.com/t5/Sky-Glass-Live/Sky-Glass-Power-up-Issues-19-9-24/m-p/4757859#M147519
Message posted on 21 Sep 2024 10:03 AM
Hi thanks for this answer. Why did it take sky so long to issue it? I found that both of my sky glass TVS were not functioning at 9 am yesterday morning. After checking the forum and only finding one comment about the issue from another customer. I searched the web and found the solution you have provided on a post from a daily newspaper within a couple of minutes. Luckily this process worked successfully for me. But I could have done with the details from sky instead of having to search for them myself.
