4306
Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by Jaty This message was authored by: Jaty
Re: Sky Glass Power up Issues 19-9-24
I found a chocolate brownie helped with the stress!
This message was authored by Sp22 This message was authored by: Sp22
Re: Tv wont turn on everytime its been off for a while
Mine is like this as well and I have tried everything it says to do trying to get in touch with someone one the phone and still waiting an hour later I also won't be paying mine until this is sorted
This message was authored by levibabe This message was authored by: levibabe
No tv
My tv is not powering up and have switched it on and off. This is the 3rd time I've had annissue with sky glass and about to chuck the whole lot out. Worst decision I ever made switching feom skyQ
This message was authored by Eastender This message was authored by: Eastender
I would not hold your breath on sky compensating us it's because they say you can watch sky go but on your phone or laptop not the same
This message was authored by Brodders This message was authored by: Brodders
Doesn't work. I'm just in a constant loop saying incorrect pin even after I select forgot your pin and reset it. It says pin reset but won't take it on the next screen.
This message was authored by Stephen+Mourton This message was authored by: Stephen+Mourton
Re: Can't get past "incorrect pin" on setting up sky stream
@RM1904  As the posts originator there should be an option to mark as answered.  I can't remember where that is off hand but it is usually obvious. Have you clicked on the little dots in the top right corner?
This message was authored by Dskywere This message was authored by: Dskywere
As of 5pm today, sky stream pucks aren't working
I did a factory reset, typed in the code displayed to link my account then it asked for my pin which it said was incorrect (I noticed the pin tries don't count up, just stays the same irrespective of actual tries) so then I reset my pin and typed in the new fresh pin and still said it was incorrect
If I chose to exclusively use the sky go app on my pc connected to my TV am I missing any content? (I'm fairly new to sky so not sure what the difference is between sky go and sky stream pucks (other than being able to save stuff on a playlist)
This message was authored by BH161 This message was authored by: BH161
My Sky Stream has not been working for nearly 24 hours now, I have tried all the suggestions given, but still not switching on. I have called customer services, but after holding for 41 minutes I got a recorded message saying lines were busy and to call back another time, not great customer service, any suggestions on next steps please?
I tried calling but gave up! It is very frustrating
This message was authored by Anonymous This message was authored by: Anonymous
Re: Still no service
Yep mines the same. Got their text about how to do the recovery and it's now frozen again whilst updating. Shambles!
This message was authored by chargomp This message was authored by: chargomp
Im gonna wait now until they actually do the patch/update they need to do ! Love sky - come on people !
Sky puck is for steaming content if you only want to stream no sky box but sky go is a app that you can watch on your other devices if you are not at home only phones and tablets
@Superzob wrote:
It beggars belief that an organisation can sell a TV which can effectively be disconnected remotely, because it has an aerial socket precisely so that it should be able to receive a signal without internet connection.
It does receive a signal (when connected to an aerial).  Unfortunately accessing the digital terrestrial television tuner and EPG is a software function that requires the operating system to be bootable.
This message was authored by Ingilybob This message was authored by: Ingilybob
    Spoiler
    Still no change for me, no red standby light on the front. Just the mic light on the side is on, reset doesn't do anything. Guess I just need to hope it'll be fixed soon.
    For now I guess I'll use crunchyroll on my tablet 🤷‍♂️
This message was authored by Bully99 This message was authored by: Bully99
I got a text from sky with the instructions to reset both my glass and puck.
I am back up and running fortunately.
Only one issue and that is discovery plus on the glass isn't working.
Locked
