2729
Discussion topic: Sky Glass Power up Issues 19-9-24
This message was authored by Super+Anthony This message was authored by: Super+Anthony
Re: Sky Puck & Sky Glass Power up issues 19-9-24
@Dazzasky Done all that
This message was authored by Van24 This message was authored by: Van24
I am back up and running
This message was authored by Denise555 This message was authored by: Denise555
It's let me activate now but I'm back to won't accept pin ! This is a nighmare
This message was authored by Emmac537 This message was authored by: Emmac537
Re: Sky Glass Power up Issues 19-9-24
I managed to get it back on this morning! Thanks
This message was authored by Kezzalar This message was authored by: Kezzalar
Mine has done factory reset, I've paired the remote now it can't connect to the broadband router. Thoughts anyone?
This message was authored by Storno This message was authored by: Storno
I've done the Sky Glass TV reboot.
On the Sky Puck TV I have the same white Sky logo, the Puck flashes then switches off and the TV shows "no signal". That repeats every 30 seconds or so.
Been the same since early yesterday evening (19th Sep).
I live in a GU postcode.
This message was authored by 84sammy This message was authored by: 84sammy
Re: Martin my sky glass TV is not turning on
Sorry just read and it was not a sky engineer it was advise from mark goldsmith thank you mark your advise had been blooming a god send 😊
This message was authored by Danielle19887 This message was authored by: Danielle19887
Re: Glass not loading red right on but constantly dims then full light again
It doesnt even give me instructions. It just does it itself 🫣
This message was authored by Cflattery This message was authored by: Cflattery
Have tried this a few times at one point the sky logi came up on the screen but now screen is black again
This message was authored by srad111 This message was authored by: srad111
Its Crazy to think this is going on in multiple countries and with  a large number of customers, for me its not about the fact there is a problem but that 18 hours later there is not a simple email to customers to say hang in there were sorting it out and here are a few suggestions for rebooting or whatever
This message was authored by RonGed This message was authored by: RonGed
I just comeback to Sky atV after long years,  but this is not acceptable please check and fix now, what a waste of money again...
This message was authored by METROBOY This message was authored by: METROBOY
I presume that effected customers will receive compensation.
This message was authored by Tolenikki259 This message was authored by: Tolenikki259
My sky glass to isn’t going on?
My sky glass tv isn't going on . The red light on the front of the tv is flashing?
This message was authored by roger1949 This message was authored by: roger1949
The glass TV is one,no the worst tech products I have every had the misfortune to have in my house,return it while you can
@Elainequigley wrote:
How do you reset if the tv won't turn on, I've no life what so ever
You have to hold the power button for ages till the red light comes on..mine flashed so I let go, then it went into recovery mode. I had no tv since about 4pm yesterday also. Mine is back on.
