Discussion topic: Signal drops when there’s heavy rain
This message was authored by: Catmomof3
My Sky glass tv loses signal every time there is heavy rain. The two other tvs using the puck are fine. I can't understand why this happens. Does anyone have any suggestions?
Thanks !!
Re: Signal drops when there’s heavy rain
Hi @Catmomof3
Given that Sky Glass channels are distributed via the internet, the rain shouldn't be directly affecting it. The only thing I can think of is that there is water ingress onto the line (if you still have a copper line) and it's slowing your broadband connection down enough for glass to have issues.
Try running a speed test in Netflix (in the settings menu) when it's raining and when it's dry and see if there is any change. If there is you would need to report it as a fault to whoever provides your internet connection.
MikeAlanR
55" Gen 2 Sky Glass atlantic blue, 65” Sky Glass ocean blue, Sky Live, 4 streaming pucks and EE FTTP Busiest Home (circa 1.6 Gbps download). Sky SoundBox. Former Sky Q, Sky+ HD and Sky+ customer.
This message was authored by: Jporch316
As @mikealanr  says also run a speed test on another device like a laptop etc when it's raining to see if there's any effect there on the line in general
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
