Discussion topic: Remote controls not working
Message posted on 09 Jun 2024 09:38 PM
None of the sky glass remote controls are working, we've been told they need to be replaced
Message posted on 09 Jun 2024 10:28 PM
							Re: Remote controls not working
Hi @Anthonyx64
Not a lot of information to go off there. Is this a new setup? If so take the back off the remote and check that some of the paper tab isn't stuck. If the back light is working on the remote, but not functioning as expected. Try unpairing and repair the remote: https://www.sky.com/help/articles/remote-control-help-sky-glass
If none of these steps work, you can order a replacement remote here: https://www.sky.com/help/forms/streaming-tv-remote
Or by speaking to Sky (we are fellow subscribers on the forum)
In the meantime if you have a Sky Q remote you can pair these to work with Sky glass.
MikeAlanR
