Discussion topic: Playlist problem
This message was authored by: Robbo7131
Playlist problem
Is there anybody have a problem watching their playlist? Able to select program but unable to watch?
Re: Playlist problem
@Robbo7131 My playlists are working correctly.  Have you tried to restart/reboot your Glass TV?  In not go to   Settings > System Management > Resets & Updates > Restart device (do not do a factory reset).  It takes about 3 minutes to completely reboot. You will have a blank screen for a couple of minutes before the Sky logo appears so don’t panic when you first start the process.
If my post has solved your issue please mark as an "Answer"
