Discussion topic: Not so smarter Sky Glass? Without package. Adding Cube.
Message posted on 18 Dec 2024 08:40 AM
I cancelled Sky TV subscription on my Glass a year ago (cost and frustration with sky marketing). I thought I was still paying for a Smarter than Smart TV, but no, it's a poor TV although a good monitor.
So I tried to re-subscribe to SkyTV - there is no option unless you buy another Glass!
So I am going the Amazon CubeTV route (like a big AppleTV puck) and will plug into HDMI.
But...I still can't get live TV channels because the Glass DTV tuner is very sensitive to aerial signal quality, so what is the best way to get streamed Freeview? I am thinking a DVTR with Freeview built in, and pass in into the HDMI in on the cube.
Anyone else in the same boat?
Message posted on 18 Dec 2024 09:17 AM
Re: Not so smarter Sky Glass? Without package. Adding Cube.
Did you call? I don't believe that's the case
Message posted on 18 Dec 2024 11:17 AM
Well I didn't call Sky to re-add, as it was at night, but I looked everywhere online to do it and it's not an option listed.
So I gave up and bought a Cube.
But need to activate Atmos and check if I play Atmos audio via HDMI that it will work.
Message posted on 18 Dec 2024 11:47 AM
If you ring sky you can resubscribe to the streaming
Message posted on 18 Dec 2024 03:05 PM - last edited: 18 Dec 2024 03:15 PM
Freeview isn't streamed: by definition it's digital terrestrial television broadcast from masts. The online adjunct to broadcast Freeview is Freeview Play, and its eventual online-only replacement will be the Freely app.
Message posted on 18 Dec 2024 03:21 PM
@Biggles123 if a device outputs audio over HDMI with Atmos the Glass TV should play it. The UHD/Atmos pack you pay for is to get access to Sky's content not to enable the hardware.
Message posted on 18 Dec 2024 04:07 PM
Both excellent information, thank you.
I am getting my core 'live' channels today from the respective apps: iPlayer, ITVx, 4, Five etc.
The Freely App will be welcome and hopefully will be on my new Cube before it gets onto Glass.
A Freeview DVTR might tune to my aerial signal better than the Glass TV, and hence stream it via the Cube, but I won't know til I try. Worst case, I fix my aerial or replace the coax cable run to get the signal quality. I just miss being able to record live TV or schedule recording something I see in the epg guide (typically a Film4 film).
Really good to hear you think the ATMOS audio should work and isn't key locked by Sky 😳
Message posted on 18 Dec 2024 04:12 PM
"If you ring sky you can resubscribe to the streaming"
Maybe, but it was so hard to find out online what that cost might be, I figured a sky agent just wouldn't get these requests often. I still don't know and bought the cube instead.
Message posted on 18 Dec 2024 04:27 PM - last edited: 18 Dec 2024 04:28 PM
Freely is a rather odd one: it's currently only being made available preinstalled on a limited range of television hardware.
https://www.freely.co.uk/products/televisions
Message posted on 18 Dec 2024 06:51 PM - last edited: 18 Dec 2024 06:52 PM
Sky Glass TVs do not support Freeview, they only support access to DTT broadcast channels via a terrestrial aerial😉
Message posted on 20 Dec 2024 01:47 PM
Very happy so far with my Cube TV connected to Sky Glass.
ATMOS seems to work, the TV definition is good. Not managed to link the remote control with the TV yet but the voice control button for the cube works in the apps which save a lot of typing.
There is even a Live TV epg type page which shows most that you need (except BBC which you still need to got to iPlayer for.
Sky News is there free, if you can stand all the ads.
Sorted for Xmas.
