Discussion topic: Not so smarter Sky Glass? Without package. Adding Cube.
This message was authored by Biggles123 This message was authored by: Biggles123
I cancelled Sky TV subscription on my Glass a year ago (cost and frustration with sky marketing).  I thought I was still paying for a Smarter than Smart TV, but no, it's a poor TV although a good monitor.
So I tried to re-subscribe to SkyTV - there is no option unless you buy another Glass!
So I am going the Amazon CubeTV route (like a big AppleTV puck) and will plug into HDMI.
But...I still can't get live TV channels because the Glass DTV tuner is very sensitive to aerial signal quality, so what is the best way to get streamed Freeview?  I am thinking a DVTR with Freeview built in, and pass in into the HDMI in on the cube.
Anyone else in the same boat?
This message was authored by Mark39 This message was authored by: Mark39
Re: Not so smarter Sky Glass? Without package. Adding Cube.
Did you call? I don't believe that's the case
Biggles123
Well I didn't call Sky to re-add, as it was at night, but I looked everywhere online to do it and it's not an option listed.
So I gave up and bought a Cube.
But need to activate Atmos and check if I play Atmos audio via HDMI that it will work.
This message was authored by peter-marlow+1966 This message was authored by: peter-marlow+1966
If you ring sky you can resubscribe  to the streaming
Freeview isn't streamed: by definition it's digital terrestrial television broadcast from masts.  The online adjunct to broadcast Freeview is Freeview Play, and its eventual online-only replacement will be the Freely app.
@Biggles123 if a device outputs audio over HDMI with Atmos the Glass TV should play it. The UHD/Atmos pack you pay for is to get access to Sky's content not to enable the hardware.
