Discussion topic: No wifi connection
This message was authored by: Amit3
No wifi connection
Sky stream hasn't worked 3 evenings in the last 10 saying there is no wifi connection but there definitely is given everything else in the house is connected to wifi.
What's the fix?
This message was authored by: Jones_The_Cat
Re: No wifi connection
What's the fix?
Tried rebooting the puck? Turn it off at the wall for a minute then power back on.
Avatar for Amit3
Yup - tried that - worked one of the times. Still not ideal. Could a new puck help of is this common?
Yeah, perhaps a new one would be worth requesting. Make sure you have network standby mode turned on - this will stop the puck having to search for a WiFi network every time it turns on.
That depends on if the puck is faulty. The way to prove this is to connect it via ethernet cable and disable the WIFI (this is usually the same steps Sky Customer Services would ask you to perform anyway if you report this issue),
When connecting via ethernet, ensure the Wifi is disabled in the puck's settings (otherwise it will default back over to the Wifi).
The sky stream puck works differently that most other internet connected devices and is essentially always communicating with the Sky servers. This means that it starts to misbehave at any point that the minimum recommended speed of 30 MBPS isn't met. Rather annoyingly if there is a short few milliseconds WIFI dropout ( which can be common due to interference and other factors but you won't tend to notice it on most devices), it will essentially crash the Glass/Stream puck, which is why the reboot fixes it (until it happens again).
This message was authored by: Misba
I need engineer out to repair
No WiFi or phone connection
