Discussion topic: New Sky Glass Air with Optical Output.
Message posted on 21 Oct 2025 07:57 PM
I can't connect it to my amplifier.
I have tried all configurations available on both.
Red light is showing, so the cable must be ok.
Really out of ideas.
Please help.
Message posted on 21 Oct 2025 09:09 PM
Re: New Sky Glass Air with Optical Output.
Hi @AntonyHead
More information would be useful for the community to assist such as the name and model of the kit you are connecting. The community will then donuts best to assist.
MikeAlanR
Message posted on 21 Oct 2025 09:31 PM
Thanks.
I'm trying to connect to connect to a Denon AVR
Regards
Tony
Message posted on 22 Oct 2025 08:25 AM
Not having a Glass Air to check here... If there is a setting on the Air under Picture & Sounds > Sound to change the output format for the optical port, try setting it to Dolby Digital (the optical connection cannot output Dolby Digital Plus) and if that doesn't work, try PCM stereo.
What model of Denon AVR are you using?
Message posted on 22 Oct 2025 07:18 PM
No option for Dolby Digital, tried PCM, no joy!
Message posted on 22 Oct 2025 07:25 PM
Chat keeps rejecting the model number,
its xray five forty beta tango.
Message posted on 25 Oct 2025 07:21 AM
I have abandoned the Optical route and connected via the HDMI arc.
