Discussion topic: Need to mount Sky Glass TV to my own stand
Message posted on 07 May 2025 03:00 PM
Message posted on 07 May 2025 03:32 PM
Re: Need to mount Sky Glass TV to my own stand
Sky will only use the stand designed for the TV. I would have thought it unlikely that any other stand could safely be used with the Glass TV. It's only local TV installers etc that might be able assess the suitability of a non-Sky stand and fit it for you, if it's possible.
Message posted on 07 May 2025 03:48 PM
A VESA compatible stand with appropriate bolt spacing should fit Glass, but that doesn't mean it's necessarily safe to do so.
The couriers were quite correct not to attempt such a thing.
