Discussion topic: Help
This message was authored by: Ann120
Help
I would like to get a sky glass but I will need someone to install it for me
This message was authored by: daveNOS
Re: Help
@Ann120 You would have to employ a local handyman or ask if any family members or friends can help as Sky won't send out an engineer to install Sky Glass.
Re: Help
@Ann120 If by install you mean simply place on the stand then you can either claim this for free via Sky VIP if eligible or pay extra for premium delivery by clicking the link in the delivery confirmation email you will receive. The basic delivery is to just drop the TV at your door. By paying for premium delivery the delivery guys will put it onto the stand and place it on your TV cabinet.
After that it's just a case of plugging the power cable into the back of the TV, switching on and following the on screen instructions (it is easy to set up).
However, if you need the TV wall mounting you will need to organise this yourself and also order the wall mount at the time of your order. If you don't it can't be ordered later, though VESA wall mounts are compatible (make sure the mount can take the TV weight though).
