3
Discussion topic: My sky remote is not working properly and its not the batteries
This message was authored by Emilyace This message was authored by: Emilyace
My sky remote is not working properly and it is not the batteries
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith Answer
Re: My sky remote is not working properly and its not the batteries
@Emilyace
Try resetting the remote
Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
Press 1 and 3 together for three seconds (bluetooth mode) and follow any on-screen instructions.
The next option sounds insane but a number of users have reported it resolving the issue with their remotes. You could try holding the remote at both ends and giving it a gentle twist as though you were wringing out a towel. It
If it is still not working have a look at the following guides:
https://www.sky.com/help/articles/remote-control-help-sky-glass
https://www.sky.com/help/home/sky-tv/sky-tv-glass/fixing-a-problem-sky-glass/fixing-sky-glass-remote...
[removed]
If you have an old Sky Q remote, you can use that as an interim solution whilst you await the new remote.
Moderator note: removed URL
Sky Stream user. Former Sky+ HD and Sky Broadband customer
This message was authored by J_Tyler This message was authored by: J_Tyler
Follow the advice here:
If it's still not working you can request a free replacement from Sky.
@Emilyace
[removed]
This message was authored by gp1511 This message was authored by: gp1511
My sky remote will not work on home menu and middle action button an 2 5 8 and 9 buttons.
