5
This discussion topic has been answered Discussion topic: Multi screen & sky glass air
This message was authored by: Ru55hnd
Can I use my multi screen box with sky glass air
This message was authored by: Jporch316 Answer
Re: Multi screen & sky glass air
Hi
we need some more detail ..... what type of multi screen ?
sky q is automatically cancelled when you order and activate sky glass or stream
sky glass air does have its own multi room system with the stream boxes and the package is called whole home
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
@Ru55hnd Only if you don't have a TV contract with the Air. You can't have Q and Glass TV subscriptions at the same time. If your Air is being used like a monitor then it's okay.
Hi
Avatar for Ru55hnd
Thank you. So the puck can be added to another Tv, streaming from the Sky glass?
@Ru55hnd The Stream puck you mean? Yes, you can use it with another TV but you will need a Whole Home subscription to do so.
As @Anonymous  says - it's the equivalent of multi room on sky q and roughly the same price
the stream boxes all share a playlist with the glass tv .
and they are all uhd capable
