Discussion topic: Motion sensor
This message was authored by: Mrben333
Motion sensor
My glass motion sensor  has not been working for last few days -all settings I believe are correct - when  it did work you had to be very close to tv to activate sensor - any advice please
Usually confused
This message was authored by: Jones_The_Cat
Re: Motion sensor
Have you tried fully rebooting the TV? Turn it off at the wall for a good ten minutes then power it back on and see if that helps. Doing this can often temporarily fix glitches such as this.
Avatar for Mrben333
Re: Motion sensor
Hi yes I have tried this and it is still the same
Usually confused
Re: Motion sensor
How old is the Sky Glass TV?
Avatar for Mrben333
Re: Motion sensor
About 1 year
Usually confused
Re: Motion sensor
Have you reported the issue to Sky... better sooner than later🤔
