Discussion topic: Motion sensor
Message posted on 26 Jan 2024 04:31 PM
Motion sensor
My glass motion sensor has not been working for last few days -all settings I believe are correct - when it did work you had to be very close to tv to activate sensor - any advice please
Message posted on 26 Jan 2024 05:17 PM
Re: Motion sensor
@Mrben333 wrote:My glass motion sensor has not been working for last few days -all settings I believe are correct - when it did work you had to be very close to tv to activate sensor - any advice please
Have you tried fully rebooting the TV? Turn it off at the wall for a good ten minutes then power it back on and see if that helps. Doing this can often temporarily fix glitches such as this.
Message posted on 26 Jan 2024 07:07 PM
Re: Motion sensor
Hi yes I have tried this and it is still the same
Message posted on 27 Jan 2024 06:44 AM
Re: Motion sensor
How old is the Sky Glass TV?
Message posted on 27 Jan 2024 09:51 AM
Re: Motion sensor
About 1 year
Message posted on 27 Jan 2024 10:41 AM
Re: Motion sensor
Have you reported the issue to Sky... better sooner than later🤔
