7
Discussion topic: Martin my sky glass TV is not turning on
This message was authored by Patsyjnr This message was authored by: Patsyjnr
My sky glass will not turn on
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith Answer
Re: Martin my sky glass TV is not turning on
I'd suggest you try reset both the remote and the TV:
Try the recovery process.
On your Sky remote, press 4 and 6 together for three seconds. This will reset your remote. Switch off your TV at the mains again. There's no need to unplug it. Press and hold the Standby button on the right-hand side of the TV.
Keeping your finger on the button, switch the power back on at the mains and wait until you see the LED lights flash, then remove your finger.Let the Sky Glass TV complete the recovery process. This can take up to 15 minutes, depending on your broadband speed.
Switch the TV back on and follow the steps on screen to set up your TV. For more help, see the Setting up Sky Glass article.
Sky Stream and Sky Broadband customer
Is this using your remote, or are you using the standby/power button on the side of the TV?
Patsyjnr
Yes I have tried that but nothing
This message was authored by Reehan This message was authored by: Reehan
Thank you so much you helped it needed an update
This message was authored by Azure_Sky25 This message was authored by: Azure_Sky25
My Sky Glass is not working. Have done all the checks which say everything is OK.
I am unable to reach the plug standby switch. Being a contortionist is not one of my skills.
When it does work I find navigation very difficult. I am 77 and disabled.
This message was authored by Kelsingra This message was authored by: Kelsingra
Posted by a Sky employee
Hey @Azure_Sky25
As you mentioned that you are registered disabled, I wanted to make sure that you know about our Accessibility Team who can give you extra support if needed.
Are you already signed up with the Accessibility Team? Once registered there are also different methods of communication with this team
https://www.skyaccessibility.sky/
Thank you for joining our Community Forum! 🙂
Fanni
Community Moderator
This message was authored by Banyan33 This message was authored by: Banyan33
Sorted my problem so very helpful thank you, my sky glass TV has reset and is now displaying the setup screen, it is however connecting to my router but telling me there is no internet connection although everything else in the house is behaving normally online, bugger!
