24 Nov 2023 11:13 PM
My sky glass will not turn on
24 Nov 2023 11:20 PM
Posted by a Superuser, not a Sky employee. Find out moreI'd suggest you try reset both the remote and the TV:
Try the recovery process.
On your Sky remote, press 4 and 6 together for three seconds. This will reset your remote. Switch off your TV at the mains again. There's no need to unplug it. Press and hold the Standby button on the right-hand side of the TV.
Keeping your finger on the button, switch the power back on at the mains and wait until you see the LED lights flash, then remove your finger.Let the Sky Glass TV complete the recovery process. This can take up to 15 minutes, depending on your broadband speed.
Switch the TV back on and follow the steps on screen to set up your TV. For more help, see the Setting up Sky Glass article.
24 Nov 2023 11:17 PM
Posted by a Superuser, not a Sky employee. Find out moreIs this using your remote, or are you using the standby/power button on the side of the TV?
24 Nov 2023 11:18 PM
Yes I have tried that but nothing
09 Apr 2024 12:00 AM
Thank you so much you helped it needed an update
08 May 2024 10:41 PM
My Sky Glass is not working. Have done all the checks which say everything is OK.
I am unable to reach the plug standby switch. Being a contortionist is not one of my skills.
When it does work I find navigation very difficult. I am 77 and disabled.
09 May 2024 09:36 AM
Posted by a Sky employeeHey @Azure_Sky25
As you mentioned that you are registered disabled, I wanted to make sure that you know about our Accessibility Team who can give you extra support if needed.
Are you already signed up with the Accessibility Team? Once registered there are also different methods of communication with this team
https://www.skyaccessibility.sky/
Thank you for joining our Community Forum! 🙂
Community Moderator
26 Jul 2024 12:58 PM
Sorted my problem so very helpful thank you, my sky glass TV has reset and is now displaying the setup screen, it is however connecting to my router but telling me there is no internet connection although everything else in the house is behaving normally online, bugger!
