Discussion topic: Last few days, technical fault with channel, disney plus etc works.
Message posted on 15 May 2025 09:32 AM
Re: Last few days, technical fault with channel, disney plus etc works.
Mine worked ok this morning but it did this a couple of other days recently and then back to normal. Also my software hasn't rolled back.
Message posted on 15 May 2025 07:35 PM
65” sky glass
Horrendous issues with "please wait for programme to load" " there is a technical fault with this programme please try again later". Blank blue screen. Internet provider adamant it's not there problem, open reach checked there system & ok, Normally resets after turning tv off, sometimes have to unplug sometimes it's off for hours, any advice welcome
Message posted on 15 May 2025 07:38 PM
Re: 65” sky glass
Sound also regularly goes out of sync
Message posted on 15 May 2025 07:40 PM - last edited: 15 May 2025 07:42 PM
Re: 65” sky glass
@Johns13 Already a thread:
It is a firmware issue that many, myself included, are waiting for Sky to fix.
A possible work around until they do, that has worked for some, is to go into Prime Video when you turn the TV on for a few seconds, then exit to the Sky Home screen and select your programme.
Message posted on 15 May 2025 07:45 PM
Re: 65” sky glass
@Johns13 The sound going out of sync was fixed for many in the last update but has been rolled back for many as it's believed to have been the update that caused the black screen error. The quickest way to get it back in sync is to move up one channel then back again. I used to get this on my Gen One TV but haven't experienced it at all after getting a Gen Two set.
Message posted on 15 May 2025 07:49 PM
Re: 65” sky glass
Yeah that works but it's annoying I also have issues if I scroll through a load of channels it's as if the tv gets confused to be honest wish I'd never been persuaded by Sky to get a glass
Message posted on 15 May 2025 08:45 PM
Re: 65” sky glass
@Johns13 wrote:Horrendous issues with "please wait for programme to load" " there is a technical fault with this programme please try again later". Blank blue screen. Internet provider adamant it's not there problem, open reach checked there system & ok, Normally resets after turning tv off, sometimes have to unplug sometimes it's off for hours, any advice welcome
Read the answer would be my advice @Johns13
Message posted on 15 May 2025 09:01 PM
So I have been having this issue for 5 weeks now and only recently have Sky acknowledged it is a wider issue.
Problems I have had;
- screen goes black while watching both normal channels or streaming apps, sound remains until you change channel or go back then no sound or vision...menus always appear fine just cant watch anything. This requires either a restart or factory reset to resolve (see below)
- screen goes black as per the above but a simple change of channel and back fixes it
- Turn TV on, Menus work fine as per the above but again black screen when selecting a channel (sometimes stating the tech fault message) or trying to stream content in app (wont buffer past 0% on iplayer or netflix for instance).
The TV being off for the whole day or overnight basically means you get the above when you turn it on. Sometimes a restart via settings works but the problem will be the same again if off again for more than circa 4 hrs. A factory reset often gets me circa 36 hrs before the probelm occurs again.
Sky replaced the TV on Good Friday but by the next morning it was the same problem on the new (refurbed) TV proving its a software issue. Since then I have struggled to even get someone to tell me if the issue is being looked at. I have provided countless descrpitions and photos and repeated what the problem is to so many advisors. I have done a number of videos showing how the problem occurs but they said they have a policy of not acceting videos.
After four weeks I asked for a refund of the TV so I could buy my own TV and take a sky stream puck (my pucks work fine). They said that technically their is nothing wrong with the TV its a problem with the operating model software so the warranty replacement policy is not triggered. Techically that is correct (a fire stick works without problems), however they advertise the TV as a all in one product so morally it feels like they are taking a wrong stance if nothing else. Given how long they have been aware of this I dont think I am being unreasonable and have tried to give them as much info as possible and cant even get confirmation they are considering it!
On the 8th May I spoke with the complaints team who promised to treat the issue seriously and handle it direct. I was promnised a call back on the 13th May wwhereby the glass tech team would have considered the referral,, however received a text on the morning to say they couldnt call and would call me on the 14th (today) ...they havent.
I still have no idea if they are attempting to fix the problem, considering it or anything. I have probably had 10+ calls and easily 10+ hrs on the phone and still no further forward.
Other points to note
- Have done the standard and full factory reset (powering down etc)
-sky have replaced the router (they sent someone out to "look at all elements", the guy whole arrived didnt work for Sky said he only dealt with broadband and had never worked on Glass! We switched over the router despite their being no issue just to give it a go but no change. The internet works fine!
- Sky kept trying to report the problem against other known issues such as "stuck on standby" rather than acknowledging it as a new issue for ages. Dealing with idiots with a set bunch of phrases all designed to get us off the call asap!
If I ever get a reponse of use will post. Sorry for length of post!
Message posted on 15 May 2025 09:27 PM
I've had 5 routers 😂
Message posted on 15 May 2025 09:40 PM
Wow! That's ridiculous.
A couple of comments suggest they might have issued a fix. My last required restart was Tuesday night, should have a good indication by tmw night if it's sorted. That might also explain why they are holding off calling me (until they are convinced it's fixed). Fingers crossed!
Message posted on 15 May 2025 09:54 PM
@Mattskyuser There hasn't been a fix issued yet. We're still waiting. What might work in the meantime is when you turn the TV on for the first time open the Prime Video app for a few seconds, then go back to the Sky Home screen and select your programme. Some have found that by doing this small step the black screen of doom doesn't appear. It hasn't worked for everyone though.
It's a pain for sure. I first contacted Sky about this issue in early April and on that first call got them to admit it wasn't an internet error because it was only the picture being lost not the sound. An internet error would cause both to be lost. It appears that has not been communicated widely and it appears it's a case of pot luck as to whether the person you speak to at Sky knows about this issue or not.
I had to call them yesterday about an issue with auto backlight option and the person I spoke to was aware of the black screen issue because we discussed it briefly.
All we can do is wait for the fix.
Message posted on 16 May 2025 12:51 AM - last edited: 16 May 2025 12:54 AM
If you'd ask me, the likely culprit is how Sky has given Amazon too much access on the TV with their app. Just so they can start showing ads on first playback of Amazon Prime content. I suspect that breaks playback of everything else, until that ad view has been triggered in Prime Video. I mean, why else would the TV spontaneously start playing Amazon Prime ads out of nowhere when using something on an HDMI connection?
It isn't the only issue. There is something chronically broken in the audio API, in the TV software. If you connect an external bluetooth device these issues will get a lot worse and practically impossible to get around without a full factory reset.
They've been aware of these issues for over a year. The first time I was told not to use bluetooth "as a workaround" was over a year ago. They haven't fixed that issue yet. So don't expect them to fix this quickly. They quite evidently don't have a functional software team working on this TV. 😣
Anyhoos... One quickfix test Sky could do is to completely remove Amazon's software on the TV. Just to confirm if that app is causing all the problems.
Message posted on 16 May 2025 06:40 AM
Yesterday morning was a false dawn, sadly - back to the same issue this morning, 'solved' with the Amazon Prime workaround. When I first turned on this morning, the Amazon Prime logo flashed for a split second before the menu loaded. A recent post stated that it is could be the Amazon App causing the issues.
Message posted on 16 May 2025 08:29 AM
Same here. Usual thing again this morning. **bleep** Sky pull your finger out. This is an absolute joke. They better have their cheque book ready.
Message posted on 16 May 2025 08:35 AM
Same here, too. Yesterday it worked for the first time in many weeks but today back to the black loading screen and having to use the Prime "fix". Something I have realised is that I am watching a Prime program before I switch the TV into standby when I go to sleep. I usually exit to a TV channel and then press standby. I'm wondering whether it's worth doing a hard reset - which will also download the firmware again - and start up from fresh. And then not run the Prime app at all. Might be worth a go to see if the TV works every day if the Amazon app has never been loaded
