Discussion topic: Last few days, technical fault with channel, disney plus etc works.
Message posted on 11 May 2025 09:33 AM
Re: Last few days, technical fault with channel, disney plus etc works.
I am experiencing the same issue every morning.
Message posted on 11 May 2025 09:47 AM
Regarding the fix, "It'll be ready when it's ready." (Fionnula, Derry Girls). Us poor customers must just suffer for weeks, it seems. Expected to keep paying and to grin and bear it - very British! 😀.
Message posted on 11 May 2025 09:48 AM
@Moreton2 wrote:
I already complained to amazon about the ads highjacking my ps5 but they said it was nothing to do with them and was probably an issue with the Playstation but it makes sense now that it's related to the problems with the TV as they all started at the same time, about 2 weeks ago
That being the case, it would probably be helpful to give Sky the information they're seeking in order to investigate il.,
Message posted on 11 May 2025 09:50 AM
Re: Channels not loading and apps not working
@chrisjanine wrote:Every morning my skyglass will not load channels or programs in apps. I have to reset it every morning. So far today I have to reset it three times.
I have tried a hard reset a couple of time and the issues is still happening
Hi @chrisjanine it's probably related to this issue.
https://helpforum.sky.com/t5/Sky-Glass-Live/Last-few-days-technical-fault-with-channel-disney-plus-e...
Message posted on 11 May 2025 10:30 AM
Have moved your posts to this current ongoing issue thread.
Read the more recent posts and the answered post within this thread from Sky on the issue and fill out the form as mentioned in the answered post.
Sky are investigating and we as Superusers are keeping them aware of many others having the issue
Message posted on 11 May 2025 10:53 AM
Hi @lettice
Are Superusers also making Sky aware that the issue is also effecting Sky Stream users? I've filled out the online form, but it only ask's if you use Sky Glass 1 or 2, no mention of, do you use Sky Stream?
Thanks in Advance
Barry 🙂
5 x Sky Stream Pucks
Sky Q Hub SR203 Sky FTTC 80Mbps
EE FTTP 1.6Gbps
Message posted on 11 May 2025 11:45 AM
Hi @lettice
Thanks in Advance
Barry 🙂
Yes, they are aware.
Fill in the form, but maybe flag in the notes at the bottom of the form that you have Sky Stream and lay out your issues, but ticked the Glass box.
We have decided to keep this thread as a combined thread for Glass and Stream and have moved the few who have mentioned similar issues with their Sky Stream within here.
Message posted on 11 May 2025 12:41 PM
Please wait for programmes to load
Message posted on 11 May 2025 01:11 PM
Re: Please wait for programmes to load
Read the last couple of pages and the answer in this thread:
Message posted on 11 May 2025 02:46 PM
sky glass gen 1
Message posted on 11 May 2025 02:52 PM
Sky are investigating and we as Superusers are keeping them aware of many others having the issue.
Message posted on 11 May 2025 03:07 PM
what form? is there a link? I will definitely fill it in as I'm super p**sed off with having to reboot my tv everytime i turn it on and getting the black screen with sound later. I don't understand why sky aren't keeping us informed or even acknowledge there is even a problem.
Message posted on 11 May 2025 03:10 PM
Yes they like to gaslight you with blaming your internet.
as for the poster mentioning they have a 55" monitor now - its barely even that, today its played Amazon Prime adverts 5 minutes into using the playstation and another time freezing with a loud jarring noise requiring unplugging each time.
All i get from Sky is 'latency' for the month, which is conincidently as long as the issue has been happening. They can't see any further back than that...so they can't see the 2+ years where it worked perfectly.
only only my 6th phone call since this first occurred, has the engineer admitted and read out the 'known issue' with version 36...they said my puck is on 35 and has no issues but the tv was updated.
the Manager i was escalated to basically said that they won't replace the tv for a second time as it won't fix the issue and they won't take the replacement TV back. They actually said that I might have to go to the ombudsman to report Sky for not delivering a service I am paying for...
at the end of the day, they are burning their customer. Back in the day, they would have sorted this, I had to push them to look for known issues before they finally admitted that.
Message posted on 11 May 2025 03:26 PM
I've got a sky glass 65" gen 1 and i'm getting the same amazon prime adverts playing just after i start playing my favourite game on the PS5, 7 times in a row it happened one time before i gave up and complained to amazon who had no idea what i was talking about, they told me to email the game developers which i did and they had not heard of a problem like that either. Then I put 2 and 2 together, the adverts on my PS5 started occuring the same time the TV started to not load the channels. Have to hard reset but then get the black screen with sound issue. I've done factory resets etc. SKY really need to sort this out as i don't think they are taking it seriously....
Message posted on 11 May 2025 03:58 PM
Have you read Sky's post, temporarily marked as the Answer?
