07 Dec 2023 02:35 PM
I received my sky tv on Monday but it's not connected to the tv. After plugging it what do I need to do
07 Dec 2023 02:38 PM
Posted by a Superuser, not a Sky employee. Find out more@Henryombah It's literally plug and play, so you connect the plug to the socket and the stream puck to your TV via the provided HDMI cable and then just turn it on.
the setup instructions will then appear on screen for you to follow.
Sky Stream user. Former Sky+ HD and Sky Broadband customer
NOT a Sky Employee
07 Dec 2023 02:43 PM
https://www.sky.com/help/articles/setting-up-sky-stream
Note you may need to manually select the appropriate HDMI port using the television set remote control (not the remote for the Stream puck)
