Discussion topic: HDR from PC does not work correctly
This message was authored by: Danb5
 this is what HDR from the PC looks like.
 and this is HDR off
I upgraded my old GPU to a 6900xt and using a HDMI 2.1 cable, monitor works fine but TV does not, I also can't really tell if ALLM is active or not, although it does feel a bit better, I don't play FPS on this TV just normal games since upgrading 2 weeks ago. Just another thing to add to the issues of this TV. My old card would display green or purple HDR and now this is just white washed, although I don't care much for HDR this display should not have this issue, my old 43 inch LG worked fine in HDR and in games.
I know it's not a gaming TV but it is a HDR capable TV other than that picture in games seem alright, Lava seems to really pop and is super bright in SDR which is nice but otherwise it does look washed still in comparison. Also does not support full RGB, I can enable it but greys become black and looks bad.
Anyone else with a PC who uses this TV experience any of the same problems? Or any advice?
This message was authored by: Abu83
Re: HDR from PC does not work correctly
Yeh its the same problem, but one thing that helped was to mess about with the picture settings.
This message was authored by: MrPete
Im having the exacct same problem. I game with my PC, My Home screen has a Gray tint to it, like your's.. But some of my games work really well, HDR seems to activate when i play these games.
But again, others don't. And Im left with a dull grayed out game.
It's actually quite annoying.
Have you found a fix?  I just don't use HDR anymore...
