Discussion topic: Can't get channels on sky glass TV. Says there is a technical fault
This message was authored by: Otisvox
Message posted on 04 Jun 2024 07:50 PM
Tried several times to get bbc1 and various other channels. Screen goes blank with circles for several minutes then it freezes and at the top of Screen reads. There is a technical fault with this channel please try later. Says that on every channel I've tried. I've tried switching tv off for a while but it made no difference.
Find out more
Message posted on 04 Jun 2024 08:01 PM
Re: Can't get channels on sky glass TV. Says there is a technical fault
@Otisvox How is the TV connecting to your hub? have you rebooted your hub?
Message posted on 04 Jun 2024 08:09 PM
@Otisvox how long have you had a Glass TV?
This message was authored by: Jporch316
Find out more
Message posted on 04 Jun 2024 08:33 PM
Hi
Fully unplug the tv for 5 minutes then plug back in
