3793
Discussion topic: Sky Glass Power up Issues 19-9-24
This message was authored by Mark1707 This message was authored by: Mark1707
Re: Sky glass won't connect
Where will I see that
This message was authored by lettice This message was authored by: lettice
Re: Sky stream down 3 days
@MarkBailey1975 wrote:
Thanks for the info I am not a sky glass customer and my puck won't even load I just get a sky symbol then it turns off wish I never left virgin now and they were horrendous I will just cancel my DD see how quick I am contacted then
This is the resolution that works, that you have to do.
It has worked for many Sky Stream puck customers like yourself over the last three days with the issue. The issue is affecting Sky Glass TV and Sky Stream customers
Follow the procedure exactly as described under the Sky Stream tab in post 2 of this thread, flagged as the Answer post from Sky.
Try holding down the button for as long as possible, it won't harm keeping it pressed longer than mentioned, but release when you see the blue screen instructions on screen.
https://helpforum.sky.com/t5/Sky-Glass-Live/Sky-Glass-Power-up-Issues-19-9-24/m-p/4757859#M147519
If you have any issue with activation during the process or entering the pin do the following;
Activation problems:
Try refreshing your browser cache or try the activate link in another browser or device.
Before clicking on the activate link, log in to your MySky account first.
Also, try this alternative link;
Make sure you have logged into your Mysky account in your browser before trying.
https://www.sky.com/productsettings/streaming-tv/activate
Also, you could try using a mobile phone, not connected to your home broadband.
Pin problems:
When at the pin stage and it fails.
Remove the power from your Puck or Sky Glass TV,  leave off for a few minutes and repower.
It will continue, follow the instructions.
This has worked for many having a pin issue
Sky Community Superuser. What is a Superuser? Click here to find out
Sky Stream (2 pucks), Sky Ultrafast + using Sky SR203 hub. Sky Protect kit tester.
This message was authored by MarkBailey1975 This message was authored by: MarkBailey1975
Thank u for the reply it's just frustrating. Also under their terms and conditions of contract they must provide an acceptable level of service and for what we pay for the basic level of tv broadband ect which they are not. We understand problems occur but going 3 days without a paid for service for most is unacceptable
This message was authored by Paulbuckland557 This message was authored by: Paulbuckland557
Re: My sky puk is not working i have no sky tv and havent since 20.9.2024
Thanks for the suggestion Lettice.
Unfortunately the only thing I can find is the big blue 'back to devices' button.
I hit that and nothing happening still, but thanks anyhoo,
This message was authored by dzy82f This message was authored by: dzy82f
Re: Sky Glass Power up Issues 19-9-24
@lettice wrote:
@dzy82f wrote:
@lettice
I'm a newbie when it comes to posting to the Community. Please could you let me know how you include the original when responding to a post?
I've tried using an Ethernet connection but it doesn't work. As soon as I plug the puck back into my TV it goes into "flashing light" mode.
When the ethernet was plugged in did you run the reset procedure again, exactly as before?
For post replying;
Click on the arrow next to the like button, then click the double quote button just above where you type your posting. That will include the text of the post your responding to.
Or you can tag someone using the @ sign and their username
Like @dzy82f
@lettice
@Daniel0210
Many thanks for your advice on quoting.
I've followed the "official" solution to the letter a number of times using an Ethernet cable. Sometimes nothing, sometimes the software downloads, verifies, downloads again and then goes into "flashing White light" mode. Sometimes I don't even get that far..
Once again, many thanks for all your help. I think it says a gread deal for Sky's apology for "Customer Service" that they have to place such a heavy reliance on customers like yourselves to support other customers.
Does anybody know of an alternative for CNN, Bloomberg and CNBC? Then I could stop using Sky altogether.
Yes that is it.
I would suggest trying the restart procedure again and hit that back button.
After a time the code runs out, so may need a retry.
This message was authored by Gillosmond6 This message was authored by: Gillosmond6
My sky stream puck has not worked for 3 days . Reset several times as per instructions still not wo
Sky streaming puck not working for 3 days . I have reset as petinstuctoons several times still not working . Keeps messaging link account but sky.com doesn't allow this . Tried to phone sky waited on phone for 2 hours still not answering .
Tried all resets still goes back to blue screen freezes then goes back to reboot page done same again goes to download and fails
This message was authored by Louisejb This message was authored by: Louisejb
I can’t connect to my sky stream at all
Is anyone else having problems it's been not working for two days now. The remote and puck are lighting up but it won't connect...
@Brian225 wrote:
Just spent 2 hours on the phone, holding on then talking to an agent. Puck now works and I'm watching the telly again. Its a software problem that stops the tv from recognising WiFi but Sky agent was able to talk me through the recovery process. So if you're without your service ring them up it'll take a few hours to resolve, enjoy your Sunday.....
@Brian225
@lettice
@Daniel0210
This seems to describe my issue. Can you describe how the agent resolved it for you?
Many thanks
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: I can’t connect to my sky stream at all
@Louisejb
I've moved your post into a large thread discussing this issue. Sky are aware and working on it. See post 2, currently showing as the answer.
▪️I AM NOT A SKY EMPLOYEE ▪️
This message was authored by Havill This message was authored by: Havill
Re: My sky stream puck has not worked for 3 days . Reset several times as per instructions still not
I've just looked bk on the customer chat and so far I've got 196 complaints ref to sky glass and the non customer service card
sky get your act together, what would you do if you lost all these customers?????
This is the resolution that you have to try.
It has worked for many Sky Stream and Sky Glass TV customers over the last three days with the issue.
Follow the procedure exactly as described in post 2 of this thread, flagged as the Answer post from Sky.
Pin problems:
This message was authored by Mark39 This message was authored by: Mark39
Have you followed the recovery process? At what point were you unable to get any further?
This message was authored by gazh425 This message was authored by: gazh425
Any ideas as to when the issue with sky glass will be sorted
