05 Aug 2023 05:06 PM
All day there is a technical issue with this channel but its every channel and its been like this all day wots going on please
05 Aug 2023 05:10 PM
Posted by a Superuser, not a Sky employee. Find out more@roman+james How is your Glass TV or streaming puck connecting to your router?
Have you tried a power down for acouple of minutes?
There aren't any reported issues with all channels doing this elsewhere as yet so may be just your setup.
05 Aug 2023 05:25 PM
Hey,
Can you explain exactly what it says/take a photo. I think I've had the issue you mention, but the way you worded it sounds a little different to me. Anyway I solved it by making sure wifi was switched off as am connected with a wire to my router, then unplugged the glass for 60 seconds exactly. It'll take a momemt but you should see the sky logo on the screen, if you do sweet leave it until it loads in if it fixes it awesome, if not or you do not see the sky logo just a red light on the glass then repeat.
