Discussion topic: 65 in sky glass 2 wall mount
This message was authored by: atlas28
Message posted on 28 May 2025 03:51 PM
Hi o was wondering if anyone can recommend a wall mount for the glass 2 65 inch as i didn't realise you had to get it when you got the tv
This message was authored by: 82bit
Message posted on 28 May 2025 04:35 PM
Re: 65 in sky glass 2 wall mount
Any VESA compatible wall mount should fit. Just get one up for the job - these TVs are weighty! And get some decent fixings to secure the mount to your wall too. Failing that, keep an eye on eBay for anyone selling the genuine Sky mount cheap.
Sky Glass 65” [Gen 2] with Sky Live
Sky Glass 43” [Gen 1] with Sky Live
Sky Stream Puck x4
Sky Sports & Sky Movies + UHD & Dolby Atmos
Sky FTTP
Sky Mobile SIMO x6
Sky Stream Puck x4
Sky FTTP
Sky Mobile SIMO x6
