Discussion topic: Sky glass picture fault
This message was authored by: louboo
Hi I recently contacted your self regarding a fault with my sky glass tv I was recommend that I change my internet package which I have done and my tv is still doing the same thing which the picture keep flickering and freezing that I am unable to do anything and have to take the plus out to restart the tv
Re: Sky glass picture fault
@louboo We are customers like you on here. You will need to ring Sky about this. Flickering picture does not sound like an internet issue to me, though freezing might have been.
Do you know what speed you are getting to the TV from your internet provider? Is there a lot of devices using the internet at once?
If your TV is less than two years old it is covered under warranty. Don't let Sky fob you off. Tell them you want it replacing as per the warranty if you feel you have a faulty TV.
Having said that, there is a known firmware issue at the moment that we are awaiting Sky to fix, which affects the TV by causing a black screen with sound and taking ages to connect to a programme. Does that sound anything like your error? I only mention it because Sky are aware of it and may mention it when you ring them. It can be temporarily fixed by signing out of the Prime Video app and doing a TV restart via the settings (not a factory reset though).
Beyond that, how are you connected to Glass? Is it via WiFi or Ethernet? Ethernet cable does give a more stable connection than WiFi. If you are connected this way make sure WiFi is turned off in the Settings.
To determine if it's a local broadband issue.
Can you do a network speed test on your Sky Glass TV.
Launch Netflix on your Glass TV (you do not need to be logged into it, if you do not use netflix) and scroll down the left menu to Get help.
Choose Check Network.
Would suggest running the test a few times, say a few minutes between tests.
What is your speed?
Going out in the latest Sky Glass/Stream QS036 software is now a new wifi reporting option.
The QS036 update is being rolled out over a month or so period, so you may not have it yet.
You can find this new feature upfront in Settings>Network
It will report a number of differing messages, based on your current wifi connection
