Discussion topic: Technical fault on TV
This message was authored by: Dave832
One of my TV's was working perfectly well, until 2 days ago when a message stating technical fault on channel was shown. I have turned router off, then back on, but it still shows the same fault. I can see all of the channels, and what all of the programmes are, but there is a black box in the corner with no programme showing.
I have also unplugged Sky from the TV and plugged back in
All of the other TV's (3) are ok.
Re: Technical fault on TV
@Dave832  Which service do you have Sky+, Sky Q of Sky Glass/Stream?
The accessibility forum isn't the correct forum for these issues so as soon as you advise which service you have we can move your post to get the right help
