Discussion topic: No subtitles - even after power cycle
Message posted on 17 Feb 2024 01:54 PM
I just moved from Sky Q to Sky Stream and have 2 pucks. I have gone to settings and turned on subtitles but nothing is appearing. I can use my Sky Go on iPad and get them but not on either puck. I have done the power cycle on them both but nothing at all. If I use the apps like ITV or iPlayer I get them on the catch up but not anything on Sky channels live or any other, even when they are showing on same program on iPad.
i did do a software update and it is showing as a later version than the website shows. So wondering if this is a very new update and has issues. QS024.012.00P (the website says QS024.011.00P) and entertainment os is 1.2
any ideas as I can't watch with out it
Message posted on 18 Feb 2024 08:30 AM
Re: No subtitles - even after power cycle
Hi there @Mark_Kaye, I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Message posted on 18 Feb 2024 09:27 AM
I fixed it by doing the following
- Turned off subtitles in settings (not sure it makes a difference)
- factory reset the box (drastic as I had set up all my apps by then)
- set up the box again
- went to a channel and turned on subtitles and it worked
- went to another channel (no subtitles as not turned on in settings yet)
- went to settings and turned it on
- all fixed
- repeated for my other pucks
