Discussion topic: Cheap-light Sky Stream Puck Remote Control
Message posted on 30 Oct 2023 11:45 AM
I did email the accessibility team ages ago..... I totally got ignored..
Will the Stream Puck get App access at all? Is there even an API in the Puck software?
The remote is so light, and as I'm heavy-handed, it moves a lot, hence making it hard to push buttons.... It needs a 10-pound weight in it!
TIA
Message posted on 30 Oct 2023 01:40 PM
Re: Cheap-light Sky Stream Puck Remote Control
Can you clarify? You can already use the Sky Stream remote to access and use the apps?
Message posted on 30 Oct 2023 01:50 PM
@Mark39 wrote:Can you clarify? You can already use the Sky Stream remote to access and use the apps?
By app access, I mean a third-party iOS/etc app like Sky Go to act as a remote for Stream........ I used the Sky+ app to control my Sky+ box.
Sorry I didn't fully explain.
