Discussion topic: Accessible Remote
Message posted on 19 Aug 2025 12:24 PM
Accessible Remote
Hi I'm looking for an accessible remote for my mother who has Sky Stream but finds the remote confusing. There are plenty of such remotes on Amazon with simple On/Off, Volume and Channel buttons but I can't find one to replace the Stream remote. Thanks
Message posted on 19 Aug 2025 12:34 PM
Re: Accessible Remote
@michael262626 Sky only offer such remotes for Sky+ & Sky Q as the Glass/Stream remote has already been designed with accessibility needs in mind, there are fewer buttons on the Glass/Stream remotes than there is on the Sky Q remotes for example.
Sky remote control accessibility features | Sky Help | Sky.com | Sky Help | Sky.com
Message posted on 30 Aug 2025 07:01 PM
The Sky Glass remote is hard for elderly to understand because the main control is an unmarked circle so they don't know what to do with it.
are there other options which work with Glass?
Message posted on 30 Aug 2025 08:55 PM - last edited: 30 Aug 2025 08:56 PM
@sue20001 No, there are not other remotes that work with Glass as Glass is a bluetooth remote
Message posted on 12 Jan 2026 06:27 PM
The Sky stream remote is hard to use for those with cognative issues/dimentia in my opnion. We find t hard to describe to a family member how to use it because there are functional buttons that have no text.
There is the large central ring and central button that is flat, no tactile raised areas. No text. What happened to an old fashioned Channel +/-, Volume +/-?
Message posted on 13 Mar 2026 01:49 AM
Hi,
there's a way to set the sky stream remote to IR mode. By pressing and holding the l4 and 6 buttons for 3 seconds. Then you can program a universal remote control with larger buttons.
Im currently in the process of doing this for my rather with dementia, this is currently the only option I can think of,.
Message posted on 22 Jul 2026 04:46 PM
Did this work, I'm having the same problem with my father x
Message posted on 08 Aug 2026 01:50 PM
If you still have your Q, buy a Sky+ HD remote and pair it via Easy Use Remote. It has the most buttons.
