Discussion topic: wifi problem
Message posted on 17 Nov 2025 11:41 AM
wifi problem
I have upgraded my wifi/broad to the new gold fibure ie. 500 mbp but the signal keeps going down to 1 cheese on the indicator and freezes during team calls.
Please advise
Message posted on 17 Nov 2025 11:51 AM
Re: wifi problem
@TheresaP if the WiFi strength is only showing as one line you will definitely hsve issues. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
