Discussion topic: wifi not working
This message was authored by Chelsea80 This message was authored by: Chelsea80
wifi not working
The wifi isn't working tidy, my partner plays xbox and cants finish as game as it always lacks connection from wifi
Re: wifi not working
@Chelsea80
Is the WIFi bad on all devices or just some? Have you run the connection test on the My Sky app?
I am NOT a Sky Employee
Chelsea80
li’ve tried testing it it says it's all good but still doesn't work sometimes and all devices
@Chelsea80
Is there anything connected via ethernet you can try and test to see if its your WiFi or the whole connection thats causing the issue
Chelsea80
no nothing connect through ethanet
